14.1 Flex Modeling and Spectrum
14.2 An Illustrative Example
14 The Flex Representation Method
During the creation of a trimmed U-spline, the modeler or analyst can choose the optimal level of effort to generate the physical atlas , which we will simply call the U-spline. Common considerations are the difficulty in generating the underlying mesh, the resulting properties of the trimmed U-spline basis, or the physical characteristics of the simulation problem to be solved. Since there is an inherent flexibility in how is modeled, we call the process of building flex modeling and the associated numerical models that process trimmed U-splines flex representation methods. In all cases, the approximation power of the higher-order, smooth, locally-adaptive U-spline basis underlying will continue to produce accurate solutions.
We call the set of all potential flex modeling approaches for a given problem the flex spectrum and denote it by and refer to a unique instance within the spectrum as . By convention, we use to represent the fully-featured, body-fitted approach (shown in figure 132a), to represent the partially defeatured, body-fitted approach (shown in figure 132b), and to represent a traditional fully-immersed approach where all geometric features are retained but immersed in a background mesh. These symbols represent the extrema of Positive integers are then used to communicate the ordering of instances or indexing along the interior of , with larger indices suggesting higher levels of immersion. A single flex model in the interior of will simply be denoted by .
In the example shown in figures 132,  133,  134, and  135, an experienced analyst has devised five potential simulations within . In figure 132, the features that the analyst has selected for defeaturing (light highlight), immersion (medium highlight), or body-fitting (dark highlight) are shown. Note that in none of these examples is the model both defeatured (thus modifying the physical domain) and immersed. This combination is possible within the flex spectrum, but omitted here for simplicity.
The U-spline associated with each flex model are shown in figures 135a,  135b,  135c,  135d, and  135e. We again note that both and have U-splines that are equivalent to their respective physical domains, while have at least part of the physical domain immersed within the U-spline. As expected, has the highest element count of the alternatives shown, due to the requirement that the mesh both fit all small features in the CAD model and be a conforming hexahedral mesh. A closeup of a partially-immersed CAD feature is shown in figure 136.
Figure 132a: : Fully-featured, body-fitted hexahedral mesh.
Figure 132b: : Traditional (defeatured), body-fitted hexahedral mesh.
Figure 132c: : Mostly-body-fitted hexahedral mesh, with a difficult-to-mesh region immersed.
Figure 132d: : Mostly-immersed hexahedral mesh, with general features body-fitted.
Figure 132e: : Traditional (fully-immersed) immersed method.
Figure 132: An example flex spectrum. The CAD surfaces that will be defeatured (light highlight), immersed (medium highlight), and body-fitted (dark highlight) are highlighted.
Figure 133a: : Fully-featured, body-fitted hexahedral mesh.
Figure 133b: : Traditional (defeatured), body-fitted hexahedral mesh.
Figure 133c: : Mostly-body-fitted hexahedral mesh, with difficult to mesh region immersed.
Figure 133d: Mostly-immersed hexahedral mesh, with general features body-fitted.
Figure 133e: : Traditional (fully-immersed) immersed method.
Figure 133: The CAD geometry that the U-spline will be fit to for each approach.
Figure 134a: : Fully-featured, body-fitted hexahedral mesh.
Figure 134b: : Traditional (defeatured), body-fitted hexahedral mesh.
Figure 134c: : Mostly-body-fitted hexahedral mesh, with difficult to mesh region immersed.
Figure 134d: : Mostly-immersed hexahedral mesh, with general features body-fitted.
Figure 134e: : Traditional (fully-immersed) immersed method.
Figure 134: A comparison of the decompositions and resulting hexahedral meshes for each approach.
Figure 135a: : Fully-featured, body-fitted hexahedral mesh.
Figure 135b: : Traditional (defeatured), body-fitted hexahedral mesh.
Figure 135c: : Mostly-body-fitted hexahedral mesh, with difficult to mesh region immersed.
Figure 135d: : Mostly-immersed hexahedral mesh, with general features body-fitted.
Figure 135e: : Traditional (fully-immersed) immersed method.
Figure 135: The U-splines for each approach. The associated physical domain, when different than the U-spline domain, is also shown.
Figure 136: Detail of the immersed region for the approach.
